morningcalm
Thread starter- Joined
- Jul 18, 2007
- 7
I have a Merc 35, serial # A151111. Anyone have an idea what year this might be? I have been through all the online sites and what they provide is far from any serial number on my engine.
Timing:
The Clymer Mercury Outboard Shop Manual does not show the Merc 35. Therefore I'm forced to follow the 40 hp timing instructions, which as far as I can tell is what they suggest to do.
My flywheel has the 2-dot mark at 27 degrees (picture below) for adjusting the timing screw on the spark advance lever. However, the solid line they recommend for final timing at high speed, does not seem to be there. From what I can tell on the flywheel, the high speed mark should be at the 9 degree mark.
Any input is appreciated.
Cheers,
Brian Kerrigan
Essex, CT
Timing:
Cheers,
Brian Kerrigan
Essex, CT
