My boat is a 1987 Capri 2150 with AQ131A and 275 outdrive. Am I correct in assuming that there are two methods for removing the engine (after disconnecting all connections inside)
1. By removing the transmission and bellows which apparently then provides access to the flywheel cover bolts. Support engine and remove bolts, pull the engine forward and up and out.
2. Don't touch the outdrive. Loosen the flywheel bolts from inside only. Support engine an remove bolts, pull the engine forward and up and out.
I really don't want to get into my outdrive if I don't have too so any advice would be appreciated. Thanks.
