U-joint Bellow install
mboudre1
Simple quick question. I just replaced all my bellows and gimbal bearing on my alpha 1 gen 2. I installed the U joint bellow on my transom first rather then on the bell housing. I know the manual says to do the bell housing first but to me is was easier to do the transom first.... Am I going to be ok. Retaining ring seemed to go on fine on the bell housing side afterwards, used lots of adhesive :)?
smassey22180
Re: U-joint Bellow install
I just did the same thing last night. I assume the directions made mores sense with the older versions that used a clamp on the outside of the bell.
Ayuh,.... Welcome Aboard,.... Haven't tried it yer's ways,...
I do bellows, step by step, as in the factory manuals, 'n haven't had any problems,...
little squirt of Power Tune, 'n the lock ring falls into place....
smassey22180
I read the manual and never found step by step for everything. Just individual items. There are 10 steps if you count each end of u joint, shift, and exhaust bellows plus water and lube hoses.
mboudre1
Well happy to say, I took the boat out 3 times and the bilge is remaining dry :). Also no more bearing noise!
Ayuh,... Congrats,... That's always nice to hear,... ;)
achris
More fish than mountain goat
Reading the wrong manual!
