U Joint Bellow Question
jorgeoliva
Ok one more question on the bellows where the clamp is the bellow have a flat side on both side does this go up and down or on the side another question when I put the hinge pin in should I use lock tite and torque to proper pounds I thing I read is 90 lb
Flats go on the sides, and if you can tell us what you have Alpha or Bravo drive and what model
