u-joint bellows grounding clips
cosander
I just bought a transom repair kit and the exhaust bellows came with 2 grounding clips and the ujoint bellows came with none. <br /><br />what function do these serve?<br /><br />Will it hurt anything not to use these on the u-joint bellows? :confused:
Haut Medoc
Re: u-joint bellows grounding clips
You should have them. They help to prevent corrosion to the ss clamps by grounding them to the rest of the drive.
novicetech
is there anyway to use the old ones?
cosander
I dont see the old ones hopefully as I disassemble they will appear
cosander
Do I glue the shift cable bellows?
