myoldboat2
Thread starter- Joined
- Jun 3, 2007
- 303
GM Engine 140 HP 4-cyl 181 cu.in.
Mercruiser "Late Model I" Stern Drive
This is my U-Joint Yoke - Coupler End 39385A 1, do you agree that the splines are toast?
or click here and then click on the picture for a close up.
How hard is it to change out the yoke? I've read the manual, and I see you have to use a bearing adapter to push out the bearings, after removing the clips. Can I do the one bearing side without removing the drive shaft from the upper unit housing? I'd rather not order the whole assembly, because it's pretty pricey.
Thanks.
Thanks.
