u joint question 1995 3.0
jmarines
I am in the process of fixing to replace me u joints in my 3.0 mericruiser. I looked at some threads and noticed a list of part numbers that cross referenced to the automotive side of things. I'm trying to go as inexpensive as possible but also to do the repair correct the first time. One of the part numbers was presion 315g. When I crossed referenced it with the OEM part there seems to be a difference in size. The OEM is bigger (L 3.63 w 1.75) and the set of cross referenced parts on the automotive side is a bit smaller ( L 2.1) Will they still work or do I need to locate new part numbers? my boat info is 1995 searay 175 with a 3.0 lx ...serial number
​449850 Any help would be greatly appreciated
jmarines
Here is a list of the part numbers on the automotive side that suppose to work.. but there different in size than OEM
SPICER# 5-1306X
ROCKFORD# K1306
DETROIT# 7260
NEAPCO# 1-6300 / 1-6301
PRECISION (MOOG)# 315G
TRW (FEDERAL MOGUL)# 20030 / 20030P
flipbro
Unless I'm missing something you can't use a u joint if it's not the same size as the the oem 1.
Bt Doctur
no your not missing anything. the size difference is if there internal C clips or external snap rings
wrench 3
The automotive usually list the length by the size of the trunnion. Maybe the OEM are measuring with the cups on.
