Uggg!! Need help!!
sewerrat
So I thought today, of all days (its 100 degrees out), would be a good day to do a prop change. First time ever changing props.
Everything went great and I have the motor in the trailering position because it was easier to work on at eye level.
Anyways, the cotter pin that goes on the prop shaft let loose from my needle nose pliers and went into the lower unit (I think).
A flashlight inspection doesn't reveal the fawkin cotter pin.
Any thoughts? Do I have to drop the lower unit? I hope not, just changing the prop was a major mechanical feat for me!
It is a 1996 Johnson OceanRunner 115hp outboard.
Thanks!
jigngrub
Re: Uggg!! Need help!!
The cotter shouldn't go into the lower unit. Try cranking your front wheel dolly all the way up and lower your motor as far as it will go, if it still doesn't come out try tapping the foot with a rubber mallet.
sewerrat
My skeg is 1/8" above the ground (ie, motor low, wheel dolly high) and nothing. It definitely when through the prop and into the tube-like thing the prop attached to. I have the prop off again, but can't find the cotter pin in there
Stachi
uhmm, maybe a magnetic retrieval tool would do you some good... there is no way the fawkin cotter key got inside of your lower unit, but needs to be found anyway...before it hurts something....if the fawkin cotter key was made of stainless steel... no magnet will help...follow jigngrubs advise and do a finger search....lol
blifsey
Man, I hate when things like that happen! The magnet idea seems like a good thing to try.
oops!
you must understand........
MR. MURPHY loves boats
sewerrat
Grrr . .ran it on muffs with the prop off hoping the exhaust would shoot it out . .no dice.
jigngrub
This calls for a full body cavity search, break out the vaseline and rubber gloves and don't stop until you reach the back of its teeth!!!
sewerrat
If only I had 14" long fingers!! No luck finding it. . .quitting for the night and will look tomorrow. I'm probably going to chalk it up as a lost cotter pin and not sweat it
glengold
i would take a garden hose and try blasting some water up there with the motor trimmed all the way down
