GilligansIsland
Thread starter- Joined
- Apr 14, 2010
- 138
Ok, I'll do my best to explain without pictures, and hopefully the symptoms will mean something to someon.
I just go a new Volvo 7.4 from Michigan Motorz which was run, timed and tested before it was shipped back to me. All I needed to do was drop her in, hook up my batteries and wire harness and start it up - that was the plan, anyway.
When I turn the key switch On, all wiring powers up as it should. When I turn the key switch to Start, I get nothing. As if the neutral safety switch is engaged. So, here's what I've done so far:
By passed the neutral safety switch - just in case
Cut out old wiring harness since it was a little loose, and directly spliced wires properly
Installed new relay mounted near the 50amp resettable breakers
Now here is where it gets weird...
I light tested all wiring from the helm harness with key in the On and Start position and everything seems good, EXCEPT when I test the Yellow/Red starter wire going into the relay. Going into the relay, I get power on the lighter guage wire. When I pierce the insulation on the heavier gauge Yellow/Red wire coming out of the relay the light lights and the engine starts kicking over!
I'll try to attach a pic of the relay.
Thanks.
I hope this makes sense to someone.
Thanks.
