Uhh...I think my drive shaft is bent-advice please
dragula
My lower unit has been off for quite sometime. Now I think that it has been resting on the drive shaft. The upper bearing housing is off...but when I spin the drive shaft it makes a big circle at the top. I think it’s bent where the oil seal would go. Looking for a cheap fix, if possible.
Should I wait to put the bearing back on and reassess?
Anybody have any experience here?
dragula
I will once I get that dang seal off. This was something I noticed after it was removed. Got laid off from work with this quarantine so my posting activity may be a little too high :)
F_R
You couldn't bend that drive shaft if you tried. Well, possibly if you ran over it with a truck.
dragula
F_R yeah it’s just wobbling around with the bearing carrier out. Not bent.
