Ultrasonic cleaners?
ShoestringMariner
Hey guys, having a problem with a carb or two.
Considering buying an ultrasonic cleaner, but I know absolutely nothing about them. Wondering if I should get one with a heater and looking for any suggestions on do’s and don’ts regarding ultrasonic cleaners.
This would be used for cleaning two-stroke carbs.
Thank you in advance
tphoyt
I use the heater and have been getting great results with a few drops of Dawn dish soap.
You can use to much and you will know when you do but the bench will be clean as well.
matt167
You can boil carbs in a light lemon juice mixture. Not too much lemon juice on carbs that are zinc coated but it’s an old trick that works well. I cook them on the stove in an old aluminum pot. It actually doesn’t stink up the house
Since today's carb cleaners suck compared to the cleaners of the 80's.
For all really cruded up carbs I do a soak in acetone (metal parts only. Followed by cleaning in berrymans (plastic part safe)
Acetone will dissolve most gummy fuel deposits quickly
Be careful with simple green..... It will eat the zinc and platings on some carbs. (Ask how I found out) .
Holley carbs are zinc castings
Mild acids will cause rusting on shafts if the plating is wore thru
Always chase every passage with fishing line and aerosol carb cleaner (or even WD40) to make sure they are clear
flyingscott
Definitely no long soaks
Faztbullet
I use formula 88 from HD mixed 50/50...be surprised on what comes out of a clean carb
