on a 1987 40hp johnson i can not unhook the shift rod. I pulled a clip pin and slide rod to left but it appears a hex nut set screw stops this from under the carbs. Do i need to release this set screw-It looks impossible without removing other parts. i am lost. lower unit is dropped about an inch so if i succeed here i could win.
