I removed the outdrive to replace the gimbal bearing. I have done this before with no issues. The problem is that now I cannot shift the lower unit. It's stuck in sort of a reverse position. I need to know what I did wrong. The way I see it there are two possibilities. I could have messed up the way the shift cable and shift lever are positioned in the upper. The other possibility is that I messed up the clocking of the shifter in where the lower meets the fork in the upper. Boat is a 1971 model year with a newer upper Sterndrive Engineering unit. The lower is a pre-alpha unit. Thanks for the help.
