Buzz Killington
Thread starter- Joined
- Apr 27, 2010
- 128
First, I apologize for this more general question here - but it involves an old boat (my '68 Thunderbird) and I figure many of you guys have had the (mis)fortune of tearing up your decks in your old boats.
This is a top down view of the rear of the boat (please contact me for prints!
I have an ancient, likely original fuel hose coming out of a small hole in the top/back of the bilge. It MUST be replaced before use...it is literally coming apart in my hands. However, I cannot get access to the point at which it connects to the tank in order to replace it. Immediately behind the bilge is about 4" of fiberglass deck, then it turns to plywood. From what I gather from the previous owner, the deck was redone and I have no interest in tearing it up all the way at this point in the resto. PO simply used a 6 gallon portable tank (for a 140hp Merc?!).
My question for you guys is where do you think I should cut a small "panel" to try and get to the tank/sender? I posted this in the Formula/Thunderbird forum and I did not get a response. I'm guessing somewhere immediately next to the fiberglass, but I have no experience with old boats/permanent fuel tanks and so this is purely a guess. Any "educated" guesses would be greatly appreciated!
Also, any suggestions on cutting into the plywood without getting into the tank would be appreciated. I was thinking about trying to find a larger cutting wheel for my dremel. I don't know if I can control my DeWalt angle grinder enough to do this.
Dave
Dave
