VaGent
- Joined
- Jul 14, 2008
- 221
Re: Underskin advice
My cross members are 16 inches on center from front to rear. The width is 49 inches side to side between my logs. My boat has the "U" shaped logs & they have a 1 ince lip on each side that the cross members attach to with SS 3/4 inch bolts. What I was thinking of doing is starting with a full 4X8 sheet at the back & wherever it ends, butting the front sheet tight up sgainst it & using a sealer to seal the joint. I was going to cut a 1 inch strip to fill in the gap along the side & seal it the same way. Is this something that will not work? Since I can butt the sheets tightly together should I still overlap them anyway? I only need 2 full sheets to cover the majority of the boat & then cut up & fit the rest around the transom & the very front of the boat.
