Understanding Mercruiser part numbers...Replacement exhaust manifold?
1lastweekend
Hi, I have a 1981 Rinker V170 with the 120HP Mercruiser 2.5L GM engine. Last fall while winterizing the boat I noticed water running down the exhaust side of the block, and immediately thought oh crap the block is cracked. I completed the winterization, but not before running the motor for an hour at idle to check the oil. Luckily I didn't make a milkshake so I thought at least maybe the crack is only external. This weekend I got the boat out and used a mirror and flashlight to do some looking around, and to my surprise the block is not cracked- the exhaust manifold is. My question is: What is the part number structure for a replacement OEM exhaust manifold? The manifold itself says 63122 C stamped on the casting, but when I Google that I get MC-1-63122, is there a "C" series casting that's different from others? Or is it all the same? Thanks for any help, love this site!!
Ayuh,..... Use the motor's serial number to nail down which manifold ya need,....
1lastweekend
Great thanks for the help, I found what I needed, should be delivered Thursday. If I get the old one off tonight, and the new one installed Friday, should be tested and on the water by Saturday I hope...
