Underwater inspection camera
UncleWillie
Re: Underwater inspection camera
I photograph underwater.
Camera seems overpriced.
Resolution is Low. 420 lines vs 1920 for HD.
You will need a PAL monitor to display the image.
WIDE is very difficult underwater.
Lights mounted on the camera will be like driving with high beams in Fog unless the water is truly crystal clear.
Do you need to view remotely or are you going down with the Camera?
Do you need to record the image?
Would something like THIS work?
H20Rat
HD isn't 1920. Its 1920 wide, but nobody uses that. Its 1080p high. So yes, this is a standard def, but lots of dedicated inspection type cams are still standard def.
But in either case, its PAL, avoid it.
Oceanlove
I guess with either option I still need to find/make some sort of pole that will allow for decent inspections. I need to view remotely. Let me give you a little more info. I'm trying to find a way to inspect the underside of my boat from the surface. Almost like a pre-flight safety check I guess. That camera looks pretty tough. Why not PAL smokingcrater? Is there a better way to do this? I'm trying to avoid hauling the boat just for routine inspections.
UncleWillie
Yes, HD is 1080 Vertical by 1920 Horizontal. (Digital)
This camera is PAL. 625 Vertical (Defined by the PAL standard) by 420 Horizontal Resolution. (Analog)
While it is a very good analog camera, it will be far from impressive once you are used to seeing HD.
It will best be compared to a quality security camera.
The field of view of any optic system underwater with a flat air/water interface is reduced by about 2/3rds.
Quality underwater cameras ($$$) use a hemispherical glass dome ($$$) over the lens to prevent this optical distortion.
That is why fish in a aquarium always look closer and larger than they actually are.
Considering the water clarity in the typical harbor, the camera will need to be within one foot of the hull to see much of anything.
A wide angle lens will image ~6-9 inch square of the hull at that range.
If the inspection is looking for anything specific it will take a long time to look at everything.
If you just need to get a general assessment of the hull, e.g. what the Barnacle density looks like, it may be OK.
Oceanlove
Excellent info! Here's another thought (keep in mind I'm an engineer and a tinkerer here): A manual periscope with some adjustment such as pan and rotate. We could affix some high quality led's to the tip. Vertical adjustment would be difficult I guess... the ultimate would a telescopic arrangement. Hmmm - this would be great for the kids in tropical waters too actually. Thoughts? I'm just thinking it would be nice to have something passive.
MWG2600
Gopro hero 2 is all you could need!
UncleWillie
I would opt for a mask and snorkle or maybe add a Snuba set.
But being in Nova Scotia it may never warm up.
Specifically, what would you be looking for?
