Shallowman
Thread starter- Joined
- Oct 11, 2010
- 114
Got the starter issue fiqured out and FINALLY was able to get the engine started . In between that thou i noticed a white wire coming from the switch box was poking thru a a slice in wire cover with 3 other wires . When i moved the white wire to tuck it back in the wire coming from either the trigger or the stator so so brittle it broke . Now its broke under the flywheel . Which does this go to trigger or stator and what does it do ?
Iam NOT knowledgable with outboards except what little i recall from helping my pops . Iam sure i heard him saying be very carefull when messing with the flywheel as it has to be removed and properly put back in place or all kind of things are screwed up .
Is this part better changed at a shop ? I can deal with changing the starter out , but if true the flywheel part worries me .
