edmaude
Thread starter- Joined
- Aug 24, 2008
- 28
I just picked up a 1983 90hp on a Boston Whaler with a 63 gallon tank on it. The fuel in the tank is pre-mixed and I pumped out approx 4 gallons today that look ok with no phase seperation. The gas smells like gas and the boat also has a remote filter which I plan to change.
Do you think I can safely run the engine with this fuel? The prior owner believes it is less than a year old. Since I did not mix it myself I can only assume it is 50/1 as well.
Also, I had a 1989 100XP on my prior boat and it had the warning alarm system. From what I can tell the 1983 motor does not seem to have the sensors on it. Does that seem right? The control is also an original morse unit, not an OMC control like I am used to
Other than the fuel issue the motor runs strong and appears to be barely used.
Ed
Ed
