wildmaninal
Thread starter- Joined
- Jul 14, 2007
- 1,897
After buying this motor that was suposed to be "froze up from sitting", I came across another Iboats memeber's thread that has me wondering if my lower unit might be the problem also.
I have the head of the motor off, I seen from the start that the top piston does have some movement in it but the bottom piston doesn't. So really I don't know which could be the problem, froze up powerhead or lower unit. As soon as I got this motor home I added my own little mixture to each cylinder to let it sit, it has been loaded down with this stuff ever sense yesterday morning. The prop will turn in neutral. The head is pretty black and somewhat caked up with carbon on the inside, the piston walls feel smooth.
My next trouble shooting ideas were to:
Take apart the prop assembly and inspect that for damage or corrosion.
Take the power head off and undo the shift linkage and drop the lower unit.
