update on 1975 25hp Johnson
poolshark38759
was able to get out and run motor in a barrel...ran semi fine...does not get too hot to touch (can leave hand 4-5 seconds before starts to get warm)..still doesnt want to idle smooth....does for a couple of seconds then misses and repeats....water is spurting out of exhaust ports that is warm..dont see where water is peeing out of pee hole(should come out under motor and to the right of boat???) water in test barrel was really oily when i finished (8-10 min test)...<br /><br />i guess it would be the intake gasket is leaking...could see gas/oil bubbling right under flywheel on left side of motor when it would miss..plugs were extremely oily after run also...<br /><br />any ideas..<br /><br />thanx
JB
Re: update on 1975 25hp Johnson
Hi, Poolshark.<br /><br />Your post is like a story that begins on page 50. What was your original post about? Why didn't you just add this update to that so we know how the story started?<br /><br />Updates and new info really needs to be added as a reply to the original post. <br /><br />Good luck. :)
poolshark38759
you can see the whole story at topic "spittin' and sputterin' "...
poolshark38759
excuse the spelling...<br /><br />see also "spittin' and Spudderin' " :D
