update on 1988 J&E 120/140 p h/bracket swap
93bronco
Ensign
couldnt find the main post so brief history-<br />got a 92 120tx that turned out to be a 1988 <br />140 TXCC.<br />it had a shoty rebuild & after pp replacement, <br />rebuilt carbs - it seemed to run good. took it out another time and it immediatley ran bad.<br />changed tstats, retorqued heads- same thing.<br />-<br />pulled heads found lots of corrosion with 4 scored pistons.<br />tore motor down to find a recirc nipple had been pinched off & hose left to suck air.<br />-<br />had gotten a 1993 125 used ph, swapped everything to it.<br />put on<br />new pp<br />used but checked stator & timer<br />used but good coils.<br />new head gaskets & resurfaced heads.<br />-<br />did a cold comp test today with all cylinders<br />rite between 120 & 125<br />-<br />had changed bracket to a 95 225 assembly.<br />put a another fast trac T/T in it and today motor kept binding.<br />had to tap on motor at times to get it to cycle<br />so i assume its bad.
93bronco
Ensign
Re: update on 1988 J&E 120/140 p h/bracket swap
replaced water pump with a complete assembly.<br />fabricated shift rod height tool.<br />lower unit went in with no problems on friday.<br />-<br />had found a new VRO (early version without wires)<br />still sealed with moisture pack reading good.<br />put that on today, blocking oil side for premix.<br />-<br />installed new tac, t/t & water pressure gauges.<br />water control valve was removed during parts swap & tstat covers updated to 1992 specs.<br />-<br />performed lync & sync today.<br />-<br /> AUGIDAWG- i am interested in getting a list of how you did yours.<br />sounds like something i would like to try.<br />how about some ideas on fabricating a spark checker.<br /> thanx
93bronco
Ensign
augidawg<br />read your idea on 'willxuout' post. thanx
93bronco
Ensign
almost done with spark checker, will post a pick of the monster in a day or 2.<br />-<br />the other question i had was if im running the 140 intake with the jetting of the 120, a #50 at the intermediate instead of #54<br />would it throw it out off tune, being the intake/reeds are different for the 140?<br />if anything i should probably be running a little rich in down sizing from the #54 to #50.
93bronco
Ensign
took it to water today to set timing per J.reeves & to check spark with homemade checker.<br />here are the results<br />-<br />intial check revealed blue spark that could be seen with brite 1pm sun directly on checker- except on #1 -changed out coil, than wire then both.<br />got good blue spark all 4 @ 7/16 gap.<br />-<br />set advance spark to mr reeves way which for me was 18-4= 14 btdc.<br />idle timing was very close to required 8 atdc.<br />-<br />verified that grounding tan warning horn wires would sound- ok<br />-<br />put all plugs back in OL78 gap .30, book called for QL77 - i figured i was going to run a little extra oil at first (40 to 1), also to help burn off fogging oil. <br />-<br />i pumped the primer holding strait up for a good amount of time to ensure no leaks & all dry lines got fuel.<br />bulb was very firm.<br />-<br />turned key on & pushing in counting to 10 & also holding in while cranking.<br />fired rite up.<br />smoked alot, took a few for pisser & gauge.????<br />-<br />idle with control in neutral was rite at 900 rpm<br />in gear 700 to 750 rpm. good for me.<br />checked all plug wires with timing lite- all good.<br />idle timing rite before 8 atdc. good<br />--<br />i let idle 5 to 10 mins.<br /> pushed in key to activate primer- it shut down. good <br />pulled plugs comp test.<br />throttle plates closed all cylinders rite between 120 to 125 psi. (same as cold)<br />wide open all cylinders 130psi<br />another spark check - all good.<br />-------------------------------<br /> now here is a problem <br />started rite back up, water gauge at 900rpm 6 to 8 psi ???<br />yes line for gauge it is at the adapter plate & not the exit.<br />looked at pisser it was getting thinner, than mixed with air & getting hot.<br />touched both tops of heads & block.<br />shut down to let cool.<br />-<br />pulled plugs comp test 130psi all, spark good.<br />figured maybe with tide coming in debri around lower unit.<br />started rite back up, pressure went to 8psi - better stream out of pisser.<br />heads/ block seemed warm.<br />-<br />with still on trailer moved throttle to 2000, psi jumped to 14, 2500 psi alittle closer to 20 psi<br />at 3000 as i felt rpm start to drop- i backed down to idle.<br />i looked at pisser and you could tell that there was air in the water & kinda hot.<br />also had water spitting out of exhaust.<br />-<br />comp test 120 to 125 closed, 130 psi all wot. good spark<br />ok dont think i damaged anything, packed up after 5 hours at landing. luckly there was no one fishing today.<br />================<br />here is my what i think is happening.<br />1- new water pump needs to be checked, along with new exhaust housing seals<br />=<br />2-power head needs to be pulled & replace new base gasket w/ new one. & retorque after intial start up. <br />i figure some of the fogging oil leaked onto gasket along with not retorquing before proceeding with power up.<br />(this time using a cherry picker instead of 2 6ft+ rednecks.)<br />=<br />3- pull heads to make sure no major damage & replace resurfaced heads with the 1993 125esx #339310 heads that came with power head<br />=<br />4-install larger elbow for hose to pisser<br />=<br />5-install new water gauge hose, as i was using 1994 bayliner speedo hose from the force motor.<br />-----<br />now something else that is odd, the new black tstats are the same ones i used on the last power head 1 time (3 to 6 hrs) before it crapped out.<br />is it possible to get 2 new bad stats or is the vernatherm a different temp setting in the black ones?<br />the other is these are the same heads just resurfaced 10ths.<br />but the comp i dont think is that high.<br />-<br />sorry so long but tried to cover everything.<br />-<br />any suggestions or input's??
93bronco
Ensign
well, after reviewing the manual (several times)<br />i overlooked the part of letting it cool after it reached operating temp on intial start up.<br />then retorquing the power head bolts, before running it.<br />-<br />thats what i get for trying to complete it before my surgery on friday.<br />-<br />it would definitly explain the water/air in pisser & upper exhaust.<br />-<br />im going to assume- being i havent gotten any suggestions that im on the rite track.<br /> especially since ive been responding to myself.
93bronco
Ensign
am going to try and change out lower gasket, in the next two days then try again.<br />is there any specific time to wait, like over nite for the 2nd torque job. or just wait til it cools enough to touch?
93bronco
Ensign
one thing i just remembered, is that although the testing of the overheat horn works when grounded, i didnot hear an overheat alarm when slow kicked in to drop rpm.<br />-<br />could the blocking diode be stopping the actual alarm even though the test of both leads work?<br />-<br />also with the 130psi in all cylinders- is that to high for the 87 octane, or should i use higher 89 or 93?
Solittle
WOW - WOW - WOW<br /><br />You have pushed my head and it's two brain cells into overload with all the info. Wish others would do half as well. My take on what you are doing:<br /><br />1. Water pressure is fine. Mine is 8-10 lbs in idle and 18-20 at 4500 rpm. Pumps are 6 months old.<br /><br />2. If you have any problem at all I would look at the tstats & pressure valve. You could test them but I would replace all as they are not to expensive. You might try a temperature stick to verify temps. I have also added temp guages to my motors (two 1987 OMC V4s).<br /><br />3. Check head bolt torque after 10 hours or break in. I just tested one of my V4s (18-20lbs) and no additional tightening was needed.<br /><br />4. Use only 87 octane - period.<br /><br />5. I think the water hoses for the tell tale are 1/4" id. Make sure you use marine tie wraps to secure. I had one let go earlier this year at 4500 rpm I blew a motor due to water injestion as a result.<br /><br />From your description I see no need to do all the other stuff you listed. With good compression, spark, timing OK etc, etc you sound OK to me.
93bronco
Ensign
am just trying to cover all bases.<br />thanx for the insite!!<br />-<br />here is the spark tester i built following rowhome's basic design.<br />
93bronco
Ensign
replaced base gasket today, the only place it sealed was to the front.<br />all around exhaust mating surface was wet with oil(top & bottom of gasket)<br />im going to guess the fogging oil that leaked out when powerhead was moved into position the 1st time prevented a good seal.<br />-<br />great care was taken this time, although when i went to pump primer bulb for a start-up it was shot.<br />so i will get to walmart & get a new one, to trouble shoot fuel system - then get an omc & keep the other for a spare.<br />so i will have to try again tommorrow.<br />-<br />i am amazed at how low the torque value is on the base power head bolts.<br />seems to me they should be alittle more than <br />144-168 in.lbs (16-19 Nm).<br />-<br />i did find about 5 head bolts that needed to be retorqued.<br />i guess that is normal.<br />comp was good after last shut down at 130psi in all cylinders.
Solittle
2K - You did a real neat job with that spark testor. What did you use to fit the plug wires to? It looks like some kind of a sliding rod but I can't quite make it out. I used a 6" screw on mine that works but I am not satisfied with it.
93bronco
Ensign
those are 5 1/2 inch lag bolts with heads cut off & slots cut in the center.<br />i drilled the holes in 2x4's so i could put rubber hose threw them to insulate the spark from traveling threw the wood, but they also serve as being able to adjust the screws - acting as a nut.<br />-<br />one other thing is the spark plug boot fits snug over the top of the hose, insulating & help keeping them in place.<br />i used fiberglass resin to keep the hose inplace.<br />it fits rite between block & cowl.<br />-<br />im probably going to cut about a 1/2 off the ends, just to have the boots go further on the hose.
Hooty
Like SoLittle sez, sounds like you've got a handle on it. He suggested Thermomelt Stiks for checking head/block temps. I finally found 'em but had a hard time. I finally wound up with a non-contact infrared pyrometer from NAPA for 'bout $80. Neat gadget for your tool box and easy to use. Just put the beam on the target and read temp.<br /><br />c/6<br />Hooty
93bronco
Ensign
thanx<br />i borrowed a friends craftsman digital temp gauge, to touch the tstat pockets on next test fire.<br />i also changed both vernatherm, just for gp.
93bronco
Ensign
havent got back to dock to restart yet.<br />so i decided to finally make a piston stop tool out of a spark plug as 'seahorse' recommended in one of my other posts.<br />-<br />i used a ngk plug that came with the 125 powerhead i bought.<br />removing the ceramic was a task!!!! <br /><br />
<br /><br />i JB welded a nut along with the hose in the cavity.<br />to keep it in place after its screwed into position, the wing nut is tightened against the hose to keep tension.<br />-<br />im going to go back & recheck timing pointer alignment with this tomorrow.
93bronco
Ensign
used piston stop to align pointer, worked great <br />-text book- wont know how much the timing is off til i get it to the landing.<br />-<br />trouble shot the primer bulb also today, it turned out to be the female quick connect letting air get by, even my spare did the same.<br />these were new and hardley used.<br />-<br />what other quick connect male/female would be more reliable?<br />maybe the old force model???
93bronco
Ensign
after doing a search on the temps of these loopers,<br />i decided to follow an old post where it was suggested to drill holes in the tstat housings.<br />i had 2 xtra so i drilled 2 #37 holes in each, just to sea what the results are.<br />-<br />still trying to find best deal on t/t motor, thats whats keeping me from testing.
93bronco
Ensign
started on hose with muffler, to check temp with modified tstats.<br />quick start stayed on for a few, than droped about 200rpm. (1000 to 800)<br />at that time i assumed it was operating at normal temp, so let in run about 5 more mins than shut down.<br />-<br />noticed timing dropped to 6dgs from 8dgs at idle so thats ok. (adjustment of pointer)<br />water pressure at 1000 rpm was 5 to 6psi.<br />volts were showing 12 1/2 to 12 3/4.<br />-<br />heads were warm when i shut down.<br />used timing lite to verify spark to all cylinders.<br />will retorque tomorrow.<br />-<br />here is a question i have 2 temp sending units - 1 gauge, is it possible to have a switch to change which sensor is used for viewing with out adding a 2nd gauge?
