Re: Update on 65hp johnson: Help!
alcan,<br /><br />What would allow water into the cylinder on these engines? <br /><br />The guy I bought it from said he thought water was getting into the cylinder, and was the cause as of the power loss..but he wasn't sure. He told me why he thought so, but I forgot.<br /><br />Don't be sorry, I'm not upset at all...I look at it as a good time to learn about outboard rebuilding basics. I've done a ford 302 and a chrysler 318 (non marine), but these marine 2strokes seem to be a whole new beast. Looks like it is time to learn!<br /><br />OK, so now what? <br />Should I go ahead and start dissasembling the 'power head', or what I would call the short block?<br /><br />How do I know if the cylinder bore is still good or not? I can feel a few grooves in it, nothing really jagged or deep, MAYBE 1/64th(+or-) of an inch on the worst one, and I can barely feel the other grooves. The grooves go up and down in the cylinder, not around it. In an automotive engine, it would just need a 'hone'...but I'm not sure how these go. I'm assuming it may need a sleeve. Here are a few pictures of the piston, you can see the cylinder wall a little bit as well.<br /><br />You can see some scarring on the cylinder in this one..a little blurry, but still viewable:<br />
<br /><br />Here is one from the other side, showing a little bit more scarring, not nearly as bad, I can barely feel it with my fingers:<br />
<br /><br />Lastly, a picture pulled away a bit. I circled a little 'port' where there was an electrical sensor of some type installed. It went thru the head and head cover, any idea what it is? <br /><br />
<br /><br />If you have any idea as to what I should do next, I would appreciate it! I am considering rebuilding it all...or buying a new engine. Every engine I have found thus far has been too large for the boat I have.<br /><br />Thanks!<br />Shawn
