dozerII
Thread starter- Joined
- Oct 25, 2009
- 6,527
Can't find the originonal thread it was too long ago. 1984 Starcraft 16ft SS 93 Johnson 90hp. Had trouble with the tach not giving me accurate readings. Replaced the regulator rectifier and finally got the boat out last week end. I was told in the last post to raise the motor one hole on the transom to get a little more rpm, this put the anti cavatation plate 2 inches above the bottom of the hull. Tried this but it just blows out on small turns and crossing wakes. It is now running at 4900 rpm at 36 mph wot with a 14 X 17 aluminum OMC prop, What recomendations would you have to raise the rpm and speed? I live in an area with no access to parts or props so must buy them through I boats, so don't want to have to buy too many.
Thanks Glen
Thanks Glen
