OK i turned the engine over to see if drive was turnind and it is. I took the cap off of the top of the outdrive, The gears and lube look good. Then i put the drive in forward gear the prop turned normal clockwize. turned counter and it would not turn so i turned it real hard and it did turn. The prop shaft turned also. But the shaft and gear at the upper gears did not. I could feel when i turn the prop the it is catching some gears but then slips.
I cant remeber is the shaft the goes thru the outdrive come in peices? If i rem correctly i think it is a 3 pc shaft. Its a Alpha 1
Could it be the shaft thet has spun?
