Beefer
- Joined
- Aug 4, 2008
- 1,737
Catch-up; When I 1st got the boat (almost 2 mos. ago), would bog and immediately stall if given throttle. Idle speed was 'ok'. Changed a bunch of stuff, which could be said as throwing parts at it, but most were regular tune-up items. Emptied fuel, and refilled with non-ethanol. Changed the anti-siphon with a new one, and then (last night) removed anti-siphon completely. Vent tube appears to be clear and free-flowing. New gas cap. New filters. New USCG fuel lines where there was (what appears to be) automotive fuel lines. That's where I'm at.
After each 'improvement', I saw improvement, and thought I was getting close. Last weekend, I started to see a correlation between bogging/stalling and less-then-smooth water. If I hit wakes, or got out to the Gulf, it would bog some, but not necessarily stall. As the FWS filter is new, I hadn't been checking it much. Last weekend when I stalled, I opened the valve, and air sucked in, then fuel came out. Then the boat would start and run fine for another 'x' period of time.
Last night, after removing the anti-siphon valve, it ran like a champ for 2 hours, and I got to play 5 miles out in the Gulf without the slightest hiccup. I figured I had it fixed. AAAAAAAAAARRRRRRRRRGGGGGGGGHHHHHHH.
Just as I got into the inlet where the speed goes down to min. wake, it hiccuped. Then, when I got to the next speed zone, it stalled once given throttle. Sure enough, opened up the FWS, let air in, closed it back up, and on my way I went.
What could be causing this? One mechanic thought maybe electrical. Another thought that there is residual water in the bottom of the carb that could be getting stirred up. Do either of these sound logical? I like the water in carb, as that would eventually work its way out, and a little seafoam never hurts.
I feel I'm soooo close to getting this corrected.
