Update Winterize to do list
BigPoppaG
I used seveal other lists posted on websites including this one to try and come up with a list I can use for proper winterization. Do me and everyone else a favor an check it over and let me know what needs to be added taken out or changed. THANKS! :D ;) <br /><br />Thanks to all who contributed to this list YOU KNOW WHO YOU ARE!<br /><br /> Preparing for Winterization <br />-Add fuel stabilizer on your last trip or before you trailer home so it has a chance to thoroughly mix with the gas.<br />-Run engine for approximately 15 minutes on muffs to ensure that the additives reach the gasoline in your fuel lines and to warm and mix the oil for changing, and flush the cooling system if you have been running in salt or brackish water. <br />-Stop the engine and check the oil level as indicated on the dipstick.<br />-Drain the oil using a hand help pump or an electric one and dispose of in a proper container.<br />-Install a NEW oil filter; and then fill the crankcase with oil.<br />-Start the engine and allow it to run at a high idle for a few minutes.<br />-Stop the engine and check the oil level as indicated on the dipstick.<br />-Clean the flame arrestor in solvent, and then blow it dry with compressed air. <br />-Restart the engine and have it running at approx. 900 rpm, spray fogging oil inside of the carburetor slowly until the engine stalls. <br />-Turn the key off. Replace the flame arrestor. -This coats the internal engine parts with oil.<br />-Remove all of the spark plugs and squirt Fogging oil into each cylinder. <br />-Replace water separating fuel filter. <br />-Drain the fluid from your engine block and manifolds, water pumps, and coolers. Frozen water will expand and crack your engine. <br />-While the water is coming out, keep sticking a piece of wire into the drain hole to make sure there is no sand plugging up the hole until it quits draining. Go to the next drain plug and do the same.<br />-Fill block, manifold, and circulating pump with propylene glycol antifreeze. <br />-Drain and replace the outdrive oil. <br />-ALWAYS have the stern drive down positon when storing for winter and draining<br />-Inspect belts and hoses. <br />-Grease sterndrive gimbal bearing and engine coupler. <br />-Clean any rusted areas on engine and touch up with paint or primer. <br />-Spray a good corrosion and rust preventive on the entire engine and electrical connections.<br />-Remove battery and store in safe, dry place. Check fluid levels. <br />-Put the battery on an automatic charger and charge it fully.<br />-Remove the prop and check for any fishing line around the prop shaft , clean and grease the shaft with a good quality marine grease prior to reinstalling the prop. If you notice nicks, dings or bends in the prop blades, now would be an ideal time to send the prop out to a prop shop for repairs.<br />-Inspect and lubricate steering and trim.<br />-Remove interior cushions and jumpseats and store in a cool, dry place. Otherwise, place cushions on end to allow sufficient ventilation. <br />-Cover the boat with a mooring cover after the interior has been allowed to dry out. The canvas will breathe and allow for sufficient ventilation of the interiors. Moisture and poor air circulation are the main reasons for rot and mildew. This can occur at any time of the year. <br />Block the trailer wheels so the tires are off the ground. This reduces tire deterioration. <br />-Loosen tie-down straps to reduce stress on the hull.<br />-Remove the drain plug. <br />-Make sure that the tongue of the trailer is higher than the stern so that any water that does get in will drain out the back and not stay in and freeze
Solittle
Re: Update Winterize to do list
Actually this is very complete. Maybe I missed it but you might want to remove the drain plug. Also make sure that the tongue of the trailer is higher than the stern so that any water that does get in will drain out the back and not stay in and freeze (if you live in a cold climate).
BigPoppaG
Thanks for the input. Any more ideas? :D
roscoe
I gotta do all that?!!!<br /><br />very nice job.
BigPoppaG
Thanks. Anything missing that you can see?
Boatin Bob
Excellent list...only thing I would do a little different right at the beginning is either add the fuel stabilizer on my last trip or before I trailer home so it has a chance to thoroughly mix with the gas. Had to find something to add :) otherwise good job!
BigPoppaG
Boatin Bob thats the kind of tweaking I am looking for. The change has been made. THANKS!<br /><br />18rabbit..............I WISH! :D :p
BigPoppaG
I did forget to ask.. is the order of the list correct or should one thing be done before the other. I tried to use common sense when putting it together but you know how that goes sometimes. :rolleyes: :p
Uncle Dave
Is fogging oil any special kind?<br />WD-40?
RedRangerVIP
Big Poppa ,<br /> Thanks for the list. I will use it tomarrow. Temp getting down in the 25-30 deg range. Awesome list thanks again!!<br /> Larry
RatFish
Big Poppa G, <br /><br />Nice job. Thanks.<br /><br />Mr. Fitz,<br /><br />Don't use WD-40. Use a fogging oil formulated for fogging engines.
Ralph 123
Great list - if you have a cuddy or enclosed spaces you can put some cannisters of the chemical dehumidifiers - they suck the moisture out of the air and deposit it nicely into a container for disposal. They work surprisingly well...<br /><br />The other thing I do is cover my engines with these mylar (like the balloons) engine covers (got them at JH Whitney site) that keep any moisture that finds its way into the engine compartment from settling on the engines. They worked great last year. They are like $10 each.
BigPoppaG
As your thanking me I am thanking you. Your input is what helped put this list together. Thanks to all you guys who helped with the input.<br /><br />GOOD IDEA Ralph!
BigPoppaG
hans007 great link. Thanks. It is now part of my routine.
briannh1234
When you are done checking the fluid levels in the battery - Put the battery on an automatic charger and charge it fully.<br /><br />- Brian
w103pcm
I am new at this boating thing. My boat and I (well, me at least, my boat has been through 40 of them already, not to tell "her" age, haha) are getting ready to go through our first winter, and I have been looking for a good "to do" list. Thanks to all on this site for all the help on restoring, running, and now winterizing her!
Mark42
If you put the fuel additive in the tank just prior to doing the fogging, take the fuel line off the motor and stick a toothpick or similar into the valve to keep it open. Then squeezing the ball, pump the gas back into the gas tank until you are sure that the additive is into the fuel line. This way you are assured that the motor is running on additive gas when waming it up.
Scaaty
If the oil filter screws in with the opening facing up, fill it with oil first. After all is done, cover the exhaust with a plastic bag/tape. Take the flame arrestor off and put a bag over the carb and put the arrestor back on. Tape over the gas tank vent. Sell the boat and move to the west coast.
