pbolden
Thread starter- Joined
- Dec 12, 2009
- 184
Hello Everyone,
Here?s the series of events. We launched our boat for the season last Saturday with about an 1/8 tank of gas (no problems). Stopped and got $100 in fuel at the marina and headed out the channel (no problems).
As soon as we cleared the channel on a heading for South Bass Island I hit the trim and the boat just stopped died. I switched from battery one to two and it started back up and we were under way again however, the tachometer is not working and the gas gauge needle is jumping sharply from empty to full back to empty then to a quarter and so forth.
Here?s what I know and don?t know. When I left the marina the gas gauge worked fine before and after refueling. What I don?t know is if the tach gauge was working. At no wake speed it would not have registered much if anything.
Additionally, the marina had just installed two new batteries sometime before launching. The next day I idled the boat for an hour to recharge battery one which it failed to do. Bad battery?
Also the next day the gas gauge is not jumping nearly as much but it is still jumping and I believe showing and inaccurate gas level of slightly less than ? tank of gas when it should be closer to ? tank.
I double checked all the circuit breakers and none where tripped. I got under the helm to check for corroded leads on the tach meter but didn?t see anything. I am not sure if the tach has a separate in-line fuse.
Hurricane SD217, Yamaha 200
If anyone has any ideas as to what happened or what?s going on it would be greatly appreciated!
Thanks,
Paul Bolden
Thanks,
Paul Bolden
