fisherman81654
Thread starter- Joined
- Sep 5, 2011
- 135
1985 mariner 175 hp Serial# A137316
I search through the fourms for an hour and found one guy had the same problem,wihout solving it,or he did not post the result.
I heated the area around the plug,and still I stripped it out.
Someone had said in a post to drill a new hole beside the other,then thread.
Is this the best solution?Or should I carefuly drill the old plug all the way through till fluid comes out and then tap to a bigger size plug?
I just finished replacing Orings and seal and I sure would like to flush the system.
Thanks....
Thanks....
