"Upgrading" a Force 9.9 to 15hp?
computerdude00
I recently purchased a 1989 Sears Gamefisher 9.9 hp in really good condition. This outboard is a Force 9.9, sold under the Sears brand. Model #2255811991. Based my service manual, the 9.9 and a 15hp have the same fundamental specs except for RPM where the 15hp runs about 500 rpm higher at WOT. Comparing all part numbers on this engine with the same year 15hp reveals that the only differences are the flywheel, reed plate, and prop (3 blade plastic on 9.9 vs 2 blade aluminum on 15hp- both 8.25"x8.25").<br /><br /> :confused: My question is simply what would be required to turn the 9.9 into a 15hp? Is there some kind of manual detuning device or governor that makes a 15 into a 9.9? Is it a matter of switching out some or all of the above parts? Changing all the parts would run around $350, and wouldn't be worth it.... however if all that is required is a new reed plate and prop, those would total $100 and would be more attractive. Would something like this even be adviseable?<br /><br />Thanks for any and all input.
computerdude00
Re: "Upgrading" a Force 9.9 to 15hp?
Just bumping the post back to the front of the forum....
sloopy
Yeah, JB <br /><br />WERE ARE YOU!!!!
JB
Hey, Dude.<br /><br />I suspect that the carb casting on the 15 has a larger venturi, also.<br /><br />If you want to do the conversion, prepare yourself for sticker shock. You will spend more than you could buy a used 15 for.<br /><br />Good luck. :)
Red Rider
I recently received a gift of a mid-eighties, Montgromery Wards 15hp motor. It is a Chrysler/Force motor branded for them. I scrounged a 9.9/9.5? hp motor for parts. The carb on the 9.9/9.5? hp is definately smaller. I don't remember if the reeds and flywheel are different or not.
