In fall of 2012 I finally got a true big lake boat. I have done some minor repairs. Replace cabin window with plexi glass gutted cabin (work in progress and have been trying to find a few leaks. I noticed near where the bow starts to rise on the underbelly are two missing rivets. can see through to daylight from either side but would like to fill the holes. Would you recommend drilling out and placing 1/4 steel mandrel and sealant rivet. I am also replacing winch want to add a fulton f2 3200 # . My islander is a 22 ft with 140 outboard and a 10hp older 4stroke honda. Floor was replace with marine grade but he did a lousy job of it did not seal it up. i gonna run it until I have to pull transom which has about 10% rot on outer edges. I coated all bad areas with wood cure and hope to pull transom next winter or year after that. Want functional boat more than anything and little nervous about biting off too much. All the bellows were professionally installed last year. I currently get about 1-2 gallons every 8-10 hours of trolling. boat sits inside now. In dont get enough water to trip the bilge float but I would like to have a dry boat someday. Anyway would like input on winch and two known bad rivets. And what size tongue jack should I get. loaded some pics but not sure if it worked
