Upholstery, restoration, star-board
john cole
I'm in the process of re-upholstering my boat interior and getting ready to do one of the seats. The base of course is made out of ply-wood, my question has anyone used that star-board instead of wood and how was and what is the cost comparison. My other question is when i asked a local "custom plastic shop" about using the white cutting board material he said that it wouldn't work, because it is UV resistant. i'm thinking it would be used a seat base out of the sun so does it really matter. Any thoughts on this anyone?
Woodonglass
Re: Upholstery, restoration, star-board
Starboard is pricey. Cutting board does not have much structural integrity as well as not having any UV protection. I would not use it. I would use plywood with several coats of epoxy and paint and fully expect the seat base to last for decades.
tpenfield
Many of the high-end boat manufacturers have switch to star-board for their seat bases. So, it is a 'go' in that regard. Not sure about the cutting board comment and even why UV resistance would make a difference.
Price-wise, you would be best to go with exterior rated plywood, as WoG advised. A few coats of water seal or epoxy and they should last 25 years or so.
john cole
1904013_724154034284888_608137574_n.jpg1904013_724154034284888_608137574_n.jpg1621762_724153997618225_998481038_n.jpg1904083_724154010951557_557816520_n.jpg1962698_724154094284882_2092543295_n.jpg
here are some pics of my seat project
john cole
and a couple more of them including a final project pic. not to bad for my first time doing this type of restoration work.
Woodonglass
John, I'd say for a "First Timer" you get one of these...
bajaunderground
Great job...upholstery is easy...making it look professional is the tough part! I think you did a pretty good job, especially for a first-timer!
~Brett
Searayb
Very nice work, congrats.
john cole
thanks, everyone, learned alot on this project. They should last a long time, I even used some canvas I had got at an auction that turned out to be to small and instead cut it up and made it into seat covers. The interior of the boat is all fliber glass / gel coat, so I'm not so worried about it being exposed to the elements, the boat canvas works great for the seats. one of these days I'll come across a piece of canvas big enough to make a cockpit cover for it. But I'm sure not paying someone else almost a $1000 to do it for me.:eek:
john cole
A couple of things I learned on this, is first never use a sharpie to mark out you material (even on the back side) because it will bled thru, which really sucks. Do several test fits, take lots of pictures (very important), stop often and review what your doing.
couple of other things, use stainless staples (don't rust, somewhat more expensive but worth it). make you cuts a little bigger then it looks, very easy to take up the slack, very hard to add material back in. Also look for sales, I got marine grade vinyl and a local frabic shop for 50% off. Which is a ton better then on line or at a marina. I used the good quality thread so it doesn't break down line regular thread. I use regular plywood which I gave a couple coats of resin and let dry good (after I cut them) so as to get the sides sealed too. Any screws and hardware I went to a local store that sold just hardware stuff in bulk, STAY AWAY FROM THE MARINE STORES for this stuff they are incredibly over priced. for instance I stoped at a very well know outdoor store and they want $9.99 for 4 thumb screws, this supply store charges .25 cents each!! How can you even compare.
jbcurt00
Monel staples are even more rust proof then stainless, but harder to find.
Make sure any thread you use is UV resistant or protected thread. Seats look good, nice work.
