I know this has probably been beaten to death, however I am still finding conflicting information on the oil seal placement in the upper housing. To make sure I am on the same wave length here I will state the following from my understanding of past threads:
1 - The oil seals have a "lip" whereby one can clearly see a retainer spring inside.
2 - The "top of the housing" is that part attached with four bolts (3/8 inch - 12 point socket required to remove)
In the manual previously posted by I believe "Bondo", Link - https://doc-0g-40-docs.googleuserco...TjhfOVRUNEk0anBUR3lQYTkwcUh5RElUQQ?e=download
In Section 3A, Page 28/29, paragraphs 14 & 15 it states the oil seals are to have the "lips" facing up, specifically on para 15 it states towards the "top of housing".
Now for the conflicting information as posted on YouTube video by "Wayne Coll" of Stern Drive in this video:
https://www.youtube.com/watch?v=qCyEW9GQFDA - specifically starting at 09:15 of the video it says to install the lower seal with the spring facing the installer. (It does not clearly show the installed seal for the upper - I cannot see the spring itself)
Please could someone clarify. Again I apologize if this has been made clear before, but I just cannot find it.
(With no ice I really should be out on the water :grumpy
