Fiat4Fun
Thread starter- Joined
- Sep 14, 2009
- 229
Howdy,
Just took my 1986 Chris Craft with a Alpha One into get winterized. They pressure tested the drive, and was low. Removed the drive, and found a small bit of oil in the bellows. It appears the seal where the drive shaft comes out may be leaking a bit. He also notice the oil was dirty ( not cloudy ) after this seasons 55 hours. It was changed out last winter, and when he drained the drive there were some metallic on the magnetic plug.
The lower end was replace with a Sierra unit in 2010, but the upper is original. Boat has about 750 hours.
Is it safe to just replace the yoke and seal or is there more to it? Is a bit of metallic on the drain plug a concern? No large metal pieces came out....
Any advice is greatly appreciated,
Bob
Bob
