Nivekt
Thread starter- Joined
- May 13, 2009
- 481
My seals are leaking and its time to replace them. The water intrusion is pretty bad. After one trip out on the lake the upper gear oil will turn completely milky. I pressure tested it and it will not hold for any length of time. I did notice that the air would leak out around the exhaust housing cover.
I did some looking around and found the seal kit to order. I know that I would have to remove the whole drive so that I could remove the upper gear case portion and then reseal. What I cant figure out by looking at the kits is exactly which seals in the exploded parts diagram are included in the kit.
Would someone mind taking a look at the picture and tell me exactly what numbers are being replaced with the kit?
Also, as a test to nail down exactly where my leak is occuring, I would like to just remove the exhaust housing cover(#72) without removing the entire drive and try to replace any seals in that immediate area. Like I stated earlier, I can see and hear the air/milky oil pushing out from around that cover when I pressure tested the upper. Is it possible to remove just this exhaust cover without taking the entire drive off?
*EDIT* Correct exploded parts diagram for my particular setup added below.
*EDIT* Correct exploded parts diagram for my particular setup added.
