upper seal kit
my3wags
Need some more help on this one too guys. resealing my upper end, cant find these seals in my manual and can't find them in the upper end. I'm stumped. got any ideas.
Thanks again for your help
cr2k
Re: upper seal kit
The 2 little plastic rings are your new drain plug seals.
The black square o-ring (called a quad ring) goes between your upper and lower it seals the oil passage.
Of course to get anymore info you must provide us with at least a clue of what you are working on.
my3wags
Re: upper seal kit
Thanks for your reply. This is for a 1990 Merc 350 260hp with a Alpha one gen one. I was told gen one because it has the plastic water pump housing not metal.
That's what I thought the two plastic ones were for the drain and vent! great thank you.
The square one is for the oil passage between the upper and lower! got it.
Could the other one be for the water pump housing for the plastic tube? I did replace one that looked very close to it in the plastic housing for the copper tube in the upper?
Thanks again for your help. this site is great.
Erik
