FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
i have a 1988 johnson 88 hp spl motor need to know location of upper shift rod bolt and what tools i need to remove bolt.
i am replaceing water pump impeller.
B. Smith,
I had that exact same motor that was on a ski boat I just sold last weekend. To disconnect the upper shift rod under the bottom carb all you have to do is pull a retaining like a diaper pin out and push the shifter linkage inward toward the engine and the shift rod disconnects for you. No need to take the carbs off to do this becuase I did a water pump replacement myself a few years ago on this same motor and it worked great. To find that shifter that you have to disconnect follow your shifter cable in where it comes from the boat back to the shifter linkage that that cable is attached to and you will see a retaining/diaper pin looking device that you have to remove first then once that retainer pin is out you push inboard toward the motor and the shift shaft disconnects. Let us know how it turns out. Bob
