jeffmc3814
Thread starter- Joined
- Sep 10, 2008
- 7
Upper swivel shaft installation
Hi Everyone, I have just refurbished my 1989 bravo one transom assembly. This weekend I will be reinstalling it. My question is on the upper swivel shaft which direction does the seal face? I know it slides down to the bottom of the shaft but face up or down? The one side of this little black plastic/rubber ring is flat and the other has a lip on it sorta. After looking at the diagrams it appears the seal is positioned at the base of the upper swivel shaft and then pushed thru the gimbal ring and then the large washer goes on under the steering lever and then the smaller washer goes on the top of the steering lever. The diagram does not show which way this seal goes on the shaft. Maybe the image is so small I just can?t tell. Any one have any experience with this? Thank you
Jeff
Jeff
