fabioemerson
Thread starter- Joined
- Oct 22, 2026
- 3
Hello everyone,
I hope you’re all doing well! I am currently restoring a boat and urgently need help identifying the exact year and horsepower of my outboard motor so that I can order the correct parts and get it running.
Unfortunately, the identification plate that should be on the transom bracket is missing. It is an OMC outboard with a manual start (I believe it’s a 30 hp Johnson, likely from around 1993 or 1994), and I have found the following numbers stamped on the engine:
Serial number on the "freeze plug" (engine block plug): 8690811
Other casting/part numbers found on the engine: 335636, 329958, 26713, and carburetor number JP432700.
Could anyone with access to OMC serial number cross-reference charts or parts catalogs confirm whether this is, in fact, a 30 hp model and provide the exact model/year?
If you don’t have access to this information, could you point me in the right direction or suggest another resource or forum where someone might be able to look up OMC serial numbers found on the "freeze plug"?
Any help or guidance would be greatly appreciated. Thank you in advance for your time and assistance!
