For my needs the only thing that has mattered was if thixotropic or orthotropic. Depending on the type work, that makes a big difference to the glasser.
bp
hey billp......yer offically a salty dawg
thats quite a long time itchin and breathin fumes...
but as far as my proj goes...where were you when the resin hit the glass?
wanna come up and do some farring?
im not sure what the difference is between these?...can you please elaborate?.....i mean what do you mean by these.
and how do these make such a big difference to the glasser?....ive been reading a bit on them today........i just love to learn
and as far as the stuff ive got.......the big companys use resin so fast they dont need a resin with a long shelf life...so they go with a different grade that gives it good properties, but does not need the long shelf life...it makes it cheeper for them to buy.
cheers
oops
Are we off topic of what?
bp
. As a side note this is the very reason I don't like to use epoxy...there is no changing ratios to make it kick at the moment you need it to. Epoxy likes to run off stringers and requires babysitting until it gels.
bp
There are also several different types of catalysts that can used alone or blended with each other to fine tune it even further and allow one resin to do several different things well by just switching between types or blends.
Billp
What you're refering to is the cure profile
These specs can be adjusted so the type of part being made cures correctly.
see coors........that polys got its places...
Yeah, but just slap on the epoxy, and not worry about poly technicalities...
While there are situations where epoxy is a much better product for the job, for the most part, the type of repairs discussed in this forum are easily handled by polyester. It comes down to what the person wants to use, it's not really a right or wrong issue and a good argument can be made for using either product.
oops,
It takes about 5 minutes to glass one side of a surfboard and the resin needs to kick asap after the handwork is complete. Pros dial the kick to happen within 10-15 seconds of the hands off stage...every time in all weather combinations.
bp
