myoldboat2
- Joined
- Jun 3, 2007
- 303
Re: Use of Sea Foam
that appears to be a lawsuit based on misrepresentation, i.e. false advertising. it does not present any new scientific evidence to debunk the sae published results.
without going through every line of the article, take this one paragraph...
According to the FTC complaint, these claims and similar ones falsely represented that without Slick 50, auto engines generally have little or no protection from wear at start-up and commonly experience premature failure caused by wear. (--misrepresentation--) In fact, the complaint alleged, most automobile engines are adequately protected from wear at start-up when they use motor oil as recommended in the owner's manual. Moreover, it is uncommon for engines to experience premature failure caused by wear, (--misrepresentation--) whether they have been treated with Slick 50 or not, according to the FTC. Finally, the FTC alleged that Slick 50 neither coats engine parts with a layer of PTFE nor meets military specifications for motor oil additives (--misrepresentation--) , as falsely claimed.
the bold clause would appear to be proven false by the sae papers--if the UBC is indeed the same as Slick 50 (i have no idea). but the bulk of this ruling is about sleazy false claims. i have no respect for the way Slick 50 or any other additive is advertised. it disgusts me. and again, i don't pour in teflon additives--i use oils that have an additive package including ptfe in an old gmc truck that i have, not in my boat (that only sees merc 25w-40, some day i may switch to their full synthetic).
but the federal trade commission is not a respected engineering society. i would think you could do better (if the papers existed, that is).
How about the FTC?
http://www.ftc.gov/opa/1997/07/slick.shtm
