Used prop purchase
captmello
http://minneapolis.craigslist.org/ank/boa/1517188986.html
This prop has been posted a couple of times on CL.
It seems like a good deal.
My question is, I currently run an aluminum 14X21p and I'm getting to the high end of my WOT RPM (4400).
Will I risk overreving with a 19p stainless or would the stainless hook up a little better at top speed...
Any advise?
Frank Acampora
Re: Used prop purchase
With the same brand and style propeller, a 2 inch pitch drop will generally run about 400 RPM faster. Stainless will run about 200 RPM faster than aluminum. So, in the worst case, you will gain 600 RPM.
However: I can not compare the Laser to your current prop but it is a reasonable assumption that the stainless will turn more than 4400 on your boat
captmello
Thanks for the reply. I was familiar with the 400 RPM difference from the 19 to 21, but not the 200 additional because of the SS. I thought it would be the opposite since the stainless was stiffer.
I guess I better stick to the 21p.
Silvertip
Just because the prop has the diameter and pitch you need does not mean its made for your outdrive so make sure of that. As for stainless vs aluminum regarding RPM gain or loss that's a very big IF! How much difference there is depends on the quality of the aluminum vs the quality of the stainless. And then the opposite is also possible. If you compare a high quality stainless to a run of the mill aluminum the difference can be significant. Prop selection is a crap shoot when you start changing more than one parameter at a time.
