Re: Using A Multimeter
Being an electronics tech losing my DMM would be like having my arm cut off...
A couple of very useful tests you can do when troubleshooting engines are the following:
1. A 'volts drop' test. One area of continuous problems is dirty terminals. Particularly battery terminals. An ohms check will not show a connection that is only resistive under high load (current). Typically these are connections to battery terminals, connections on starter motors and solenoids. To test for unacceptable drop, put the multimeter on a small voltage range, typically the 2 volts range. Put one lead of the meter on the terminal and the other lead on the cable. You are measuring across the actual junction between the two. The meter should read
very low, very close to zero. Now activate the high current device, like the starter motor, you should see a small increase in the voltage reading, but only very small. A reading of 0.1 volts is unacceptable and means the terminal needs cleaning.
2. The other function you'll find useful is the diode test. This is, surprisingly enough, for testing diodes. Test each leg of a bridge rectifier with this. Remove all the leads on the rectifier. Set the meter to diode test (-|>-) and put the red test lead to the + terminal (or red wire of a rectifier with wires not terminals) on the rectifier. With the black test lead touch each of the ~ terminals/yellow wires. You should get 'OL' on the meter, meaning open circuit. Now put the red test lead on the - terminal/black wire (or the metal body of a rectifier with only 3 terminals/leads) and touch the black test lead to each of the ~/yellow wires. You should see a reading of about 0.7 volts. This is the voltage drop across a diode that is 'forward biased'. Now put the black test lead on the + terminal/red wire and touch each ~/yellow wire with the red test lead. You should see 0.7volts on each. Black lead to the - terminal/black wire/rectifier body and touch each of the ~ terminals/yellow leads and you should see 'OL' (this means 'Overload' or more than the meter can read, you won't damage the meter, in diode test this means open circuit). If any of these readings are out or any reading is 0 volts, then the rectifier has GTG (gone to god
One of the most useful equations in electrics is V=IxR, Voltage equals current times resistance. Rearrange it to fit what you have, like I=V/R if you want to know the current or R=V/I if you want to know the resistance.
The other equation is P=IxV. Power (in watts) equals current times voltage. Mix the two equations together and you have the most powerful maths in electrics. It's all I've ever bothered to remember in more than 30 years working with electrics.
Let's say you have a light you want to put in. The light is a 12 volt, 50 watt unit. What size cable should you use? For that you need to know the current drawn by the light. Easy... remember P=IxV, can also be I=P/V... current=50/12 (amps), or 4.16 amps. Find a cable that can carry 5 amps and you're giggling. It also means that the light has a resistance of... let's see if you can work that out.
Cheers,
Have fun with the multimeter ('probing' the dog is NOT funny!!! or legal in some states
Chris.............
