Using a rear anchor on a Pontoon Boat.
Silver Eagle
My Boat is squared off on the back. The motor is covered by the rear deck.So where do I mount the line for the rear anchor.All I have is a welded cleat for taking to boat out of the water at the far end of the toons front and rear.I drilled a hole in the front center of the boatand put in a large eye boltso far this has worked for the front But I can't find any place to put one at the rear.
EGlideRider
Re: Using a rear anchor on a Pontoon Boat.
You could put a U bolt or cleat into the deck if there is room. You can also put a cleat on the top rail if you do so near the sides or at a place with a diaganol brace. Of course you would not use the rail cleats if water and wind conditions place a lots of strain on the rail. Actually you should never use a stern anchor in these conditions anyway.
Silver Eagle
Out on the bay we anchor our boats forward and Aft so our boats don't hit each other ,otherwise we'd have to take up a lot of swing room. Most of the boats are side by side. I don't like to do that but some times we have too. It gets pretty crowded on weekends.
lncoop
If you can easily reach the lift eyes I'd just use one of them.
