using bedliner on a fiberglass hull
jah1317
I am fixing up a well used 12' gamefisher trihull (fiberglass) and I have a few questions about painting it after I do some hull repair.I will be painting below the water line and I was thinking about hitting it wit a universal primer and then topcoating it with bedliner. I have seen it done on the linex site and am thinking it would do for what i need. I am going to be using this boat in a small stream near my home and a local lake while fishing for musky...... any thoughts. I am fixing it up and creating some casting decks and storage areas and I will be posting some pics throughout the process. Thanks for the imput.
jacob
chrishayes
Re: using bedliner on a fiberglass hull
still thinking of doing this to my deck, mind being my guinea pig? Keep us posted!
danond
Get into a friends pickup, then fall to your bare knee or elbow onto the bedliner. Now, go get a bandaid or wound dressing.
That's why bedliner isn't used in boats :D
cdyer77
being in the same (literally) boat as you, I'm looking to paint my glass gamefisher too. I thought about adding some decks, but want to see how stabil the boat is first before spending time & money on decks.
Please keep us posted.
Zetman
I used Herculine (SP) in my boat went on very easy and I love the results..as for getting scraped by it I just hit it down with an air sander very lightly and it is still non-slip but a little smoother on bare feet,arms etc.. Zet you can get it in grey color too
Bob_VT
Google durabek and look at what that is. They have colors for marine applications too
Yacht Dr.
From what I read in your question..your only using this on your hull/bottom ? If so then rhino line if you want to..
dunno why..but if thats all you have to work with ( cost, availability .. etc. ).
YD.
jah1317
I am only using it on the bottom of the hull of the boat on the top I am looking into rustoleum (sp) for above the waterline. I don't need it to look pretty, and honestly, I bought the boat for $20 and just want to make a highly functional reliable boat that has minimum maintence and if you have ever tried to get bedliner off well, good luck. I work at a paint shop and have been checking with our suppliers and salesmen as well as my bed liner guy and we are thinking it would be a pretty good application for a good pricetag. Who knows! I will post as it goes. As for the casting decks, I am making them the same height as the seats because I have a friend who has the same boat and he stands and fishes from them with out a problem.
Take care,
Jacob
jah1317
Take care,
Jacob
escapade
I did a google search on durabek, however could not actually find there website, just a bunch of links to websites where people talk about it, I'm going to be trying the dupli-color system when I complete my deck
cdyer77
The product is DURABAK, thats why you coulndt find it - Here's the link
http://www.nonslipcoating.com/marine.htm
Its not realy meant to be used (As far as I can tell) for below water line applications, its more for decking
jah1317
Escapade, check out the following link for durabak. http://www.nonslipcoating.com/ also check out the applications on the rhino linings site http://www.rhinolinings.com/applications/marine/boat_detail. These are what brought the idea to my mind but I wanted to see if anyone else out there had tried it and how it worked thats all. I know that we tried getting some liner off of the insider of a street sweeper tank and we gave up and we were using a sandblaster and some heavy grit!
jacob
57chris
Hey jah1317 post some pics of that Gamefisher man, i've got an old trihull front fiberglass 12'er myself...would love to see yours, and your buddies with decks installed, good to hear it's stable with fishing decks. :cool:
cdyer77
Ditto on that!!
cdyer77
By the way, does anyone else here that has a fiberglass gamefisher get the feeling that their transom flexs too much???
I just put a 7.5 hp motor on the back of mine & seems like the transom flexs alittle more from the added weight - I went from 3 hp to 7.5 hp. Its not so much the transom itself as the whole rear of the boat.
Anyone else have a similar issue?
