Using parts of a 1974 85hp on a 1973 115hp
wojciecj
I have a 1973 johnson 115 with a bad lower unit. I thought I would buy a parts motor to use the lower unit. Correct me if I'm wrong but would any lower unit from a 85-135hp johnson/evinrude from 1973-1979 work? I also don't know if the block is the same size on this motor range. Having a parts motor would I only be able to use the electronic components or are parts such as the cylinder heads the same? I just don't know what causes the horsepower change between the 85, 115, and 135. Is the bore slightly larger, are the carbs larger or both?
Hooligan Diver
I was able to use the lower unit from an '87 150 on my '79 235. Both being V6, and between crossover years '79-'91. I would think up to '78 would work, but I'd cross reference that to be certain before spending any cash...
wojciecj
Thanks for the replies. Are all the cylinder heads interchangeable between 85-135hp?
