four winns 214
Thread starter- Joined
- Oct 25, 2008
- 780
To release pressure on the serpentine belt for removal, I used a 3/8” ratchet in the square hole on the belt tensioner that’s designed to facilitate rotating the tensioner for belt removal. During that process, the metal flange in which the square hole is stamped broke before I could get the belt removed. Since I could no longer use the ratchet to rotate the belt tensioner, I pushed down on the top of the belt tensioner to relieve the pressure on the belt and was able to remove it.
It appears the only damage done was the broken metal surrounding the square hole. This is my first time removing a serpentine belt. What is the best way to raise the belt tensioner when I want to reinstall the serpentine belt? If I have to replace the belt tensioner assembly, is there any exotic to that?
