KrisPbacon
Thread starter- Joined
- Oct 29, 2019
- 3
I have a 2003 fourwinns 328vista with twin V/P 5.7 gi-D model engines. My port engine will not go over about 3400 rpms under load. It will in nuetral. The scanner showed no codes. It has new plugs, csp, rotor and wires and fuel pump and filters. Compression test is 180 top and 155 bottom. vacuum test is a steady 14. Fuel pressure is 45psi at the rails. The engine idles a tad rough but nothing crazy and it accelerates smooth and steady up to 3400 but thats all it’s got if the other engine is WOT. If i back the starboard engine back to synch them up the port will drop to 3100 once its lost the help of the other. Any ideas?
