Sorry for the long post:
1995 Evinrude V4 looper 130 HP
Oil side of VRO disconnected and VRO wiring harness disconnected
Running fresh gas, 1:50 ratio
Champion QL78YC
New rectifier
New power coils and plug wires
This issue has been bustin my balls for two months now.
I started chasing an ignition problem but it seems I have a fuel problem too. Started thread at S&F but no response there.
For reference: http://www.screamandfly.com/showthre...on-3-cylinders
Engine ran fine for whole season, until the idle started to be rougher and rougher, until the point where I am now. It will still run perfectly mid-range and WOT.
Engine will start up always within a few turns after using the primer, altough pretty rough, and runs rough in general at idle. It will idle around 900-1000 rpm in the water when trimmed level or higher. When trimming fully down, idles drops to like 500 rpm and it runs really really rough, dropping cylinders. It smokes pretty much in general, more than I can remember from the past season. Since I'm not that close to the water the rest of the tests below were performed on the hose - the problem also occurs on the hose, so it's not related to backpressure, engine does not sit too low in the water, idle relief holes are above the water line at all times.
At the hose, I find that when the engine is trimmed lever or higher, and I trim it full down, the engine drops to like 500 rpm, but will clear up after 30 sec or so and be back at around 1000 rpm. Still runs rough though.
I am pretty sure the engine is running rich. My shining SS prop is now covered in grey/black deposits and the motor smokes a lot.
I noticed that carbs are spitting fuel through the intermediate or idle orifice, not sure which one. I think the upper one, which is intermediate.
What I did:
- Checked compression, 125 PSI on all four.
- Checked ignition to make sure that was all good. All values (stator, timer base) are within spec, altough resistance of the stator is 395 ohm, bit lower than the value in the book.
- Timing is set to 4 ATDC at idle. Timing does not jump around, is spot on and not intermittent or something, on all 4 cylinders.
- QuickStart is working properly.
- Openend up carbs, looked perfectly clean, set floats dead level with gasket surface. Two of the floats were set too low.
- Discovered that the (#^#$^#$ plastic) float bowls were warped, wet sanded them on 600 grit until it was level again.
- Checked head temps while running, both in spec (around 150 degrees).
- Checked VRO pump for fuel leakage through the pulse fitting, no leakage was found.
- Cleaned all recirculation hoses, none were dirty.
- Cleaned all fuel lines, none were dirty.
What I did find:
- Discovered that all 4 check valves in the intake manifold and the check valve from lower to upper bearing were
broken, let fluid through in both directions, need to replace them.
Now, I didn't buy rebuild kits for the carbs yet. But none of the carbs are leaking fuel, and I can pump the primer bulb as hard as I want, when the carbs are full, they are full. I cannot keep priming the bulb. I think that tells me that the needles are properly seating? Carb kit that is in now is about 2 years old.
Now my main question is, can these broken check valves cause these problems? Since they are ALL broken, I can't imagine that they all were good during the season (when the motor ran just fine).
Any more questions, input or advice is much appreciated. What more can be trim-related? What makes this engine run rich? This thing is driving me mad and I feel like i'm missing something.
Champion QL78YC
New rectifier
What I did:
What I did find:
