V6 lower unit prop shaft
maineiac5586
I have this v6 lower unit but the end of the propshaft splines look strange. Anyone see this before? What could cause it? Will it work ok? Thanks
Chris1956
Honorary Supreme Mariner
You can chase the threads, and clean up the splines with a file. Not sure what caused it, perhaps ill fitting prop splines and an ill fitting prop nut?
Will it work, probably....
